Discussion topic: eSim PAC code
This message was authored by: Josh552
eSim PAC code
So Im trying to activate a eSim because my actual normaly sim is disabled so I cant really use my phone for calls messages etc but it says it needs the PAC code for my phone is there another way to get this code like can a Sky Employee Private Message me on here and obviously get the details they need and give me the code that way as I cant recieve calls or texts?
Re: eSim PAC code
@Josh552
If you are trying to transfer your mobile number from the sim card to the esim then you can not do this as it isn't possible to transfer a number like this within the same network. You should be able to activate and use the esim with a different number.
