3
This discussion topic has been answered Discussion topic: Valuation on phones
This message was authored by: Chris3451
Valuation on phones
The value of my phone is still a lot and I would like to upgrade on it? How does the valuation of it work and can I pay monthly on it just have to be a one time payment?
Re: Valuation on phones
If you upgrade or swap it and the value Sky gives you for it is not enough to pay it off then the difference is added to your next available bill so you would need to paid off in the go on it.
Avatar for Chris3451
Thank you for your reply, so the cost of the valuation is abouts 500 pounds does that need to be payed in one go then if I upgrade?
It depends on what you still owe against the phone and how much Sky says it is worth, you should see this should you go ahead and place an upgrade or swap order and you can decline anything offered if you believe the value Sky says your phone is worth is to low.
