2
This discussion topic has been answered Discussion topic: Using sky unlimited mobile in spain
This message was authored by: paulmitchell1984
Is it free for me to use my sky mobile abroad in Spain ?
Re: Using sky unlimited mobile in spain
@paulmitchell1984
No. For Spain it should cost you £2 for each 24 hours use of your home allowance.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage duel to overuse. I'm not aware of the rules being different if on an unlimited plan.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy
@paulmitchell1984
No, they're not.  The 'unlimited' plan does not give your uncapped usage abroad.  (Nor at home for that matter)
