Discussion topic: Using my mobile in Thailand
Message posted on 29 Dec 2024 08:26 AM
Hi I'm going to Thailand for a month and I'm wondering how much it will cost to have full coverage and data while I'm there
Message posted on 29 Dec 2024 08:33 AM - last edited: 29 Dec 2024 08:34 AM
Re: Using my mobile in Thailand
Hi @Marcus6 have a look at page 12 on the link below. Bear in mind it's £0.36 per meg not gig. It will be very expensive to use your sky sim there. The best way to avoid high charges is to turn off roaming and mobile data then activate flight mode BEFORE leaving the UK, not in the air or on arrival. Use free WiFi by turning on WiFi only when you get there. The other option is remove your sky sim and use a local sim.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
