Discussion topic: Using mobile in Mauritius
This message was authored by: JC133
Can I get or use an eSIM
Do sky offer a travel deal?
Re: Using mobile in Mauritius
@JC133
There is no package as such. It is a Rest Of The World destination and costs will be extremely high as per this link
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
The cheapest solution is to get a local SIM card when you arrive or only use free Wi-Fi.
You need to make sure roaming / data are switched off before leaving the UK and switch on flight mode.
Avatar for JC133
Thank you!
Will I need to get my phone unlocked?
If you bought it from Sky, no.
Hi @JC133  all phones supplied by sky are unlocked and can be used with any network.
All Opinions Are My Own
Avatar for JC133
Thank you so much.
