2
This discussion topic has been answered Discussion topic: Using mobile in Asia costs
This message was authored by: KeithBennett1
I'm travelling to Hong Kong - Vietnam-Thailand & Singapore how much would it cost to use my mobile for recieving local calls and data usage? Do you to an Asia travel pack upfront?
Re: Using mobile in Asia costs
@KeithBennett1
Sky doesn't do Asia roaming packages so you pay for what you use as you can check yourself here:
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Rest of the world charges are usually this but can be even higher:
£2,160 per GB (yes this is correct)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
@KeithBennett1
Potentially far more than the airline tickets, so be careful: you really don't want a UK SIM active when you land (and it's best to disable cellular data services on departure to avoid any risk of overflight charges ; )
Note that unfeasably high cellular data costs would typically also apply in, for example, a Gulf state stopover (apart from UAE which, for some reason, is one of the few nations outside Europe with £2 roaming on Sky Mobile)
