Discussion topic: Use PAC Code twice
Message posted on 04 Nov 2024 04:08 PM
Use PAC Code twice
Can I use my PAC code that is due to expire in 4 days with new provider even how used it two weeks ago to leave Sky Mobile but decided to go back but want to leave again but get error message when request PAC code how one already there.
Message posted on 04 Nov 2024 04:10 PM
Re: Use PAC Code twice
If the PAC was already used once when you left then you can't use it again so you would need to brain another one.
Message posted on 04 Nov 2024 04:15 PM
@caesarome It was used once but why is it still there on my account next to number I moved from Sky & back to Sky before it expires.
Message posted on 04 Nov 2024 04:18 PM
I have no idea why it is still there. If it isn't working try another one or call Sky for advice.
Message posted on 04 Nov 2024 04:21 PM
@caesarome I haven't used it but if I do what would happen if doesn't work , would I lose both mobile numbers or would new mobile provider reject PAC Code ?.
Message posted on 04 Nov 2024 04:25 PM
If you haven't used it then it should work if you obtained it 30 days ago or less. If it fails you just get another one if it is older than 30 days. You will not lose anything related to the number as all that would happen is the number would stay where it currently is.
