2
This discussion topic has been answered Discussion topic: Urgent help needed
This message was authored by: Andy+Lin
Urgent help needed
Does anyone know what the charges are to use sky mobile when in mexico
This message was authored by: PandJ2020 Answer
Re: Urgent help needed
£2,160 per GB of data (Yes, just over 2 THOUSAND pounds)
£2.16 per MINUTE to call UK
£1.80 per minute to receive calls
50p per SMS
£3.50 per minute to call local numbers
50p per SMS
Best get a local sim and use that while you are out there so if taking your device abroad make calls mobile data and roaming are turned off and it is flight mode before you leave the UK.
