Discussion topic: Two-step verification code not working
This message was authored by: shopping
Still not getting any code being text from Sky to be able to get into my emails - how much longer will this take to be fixed? Can this not be removed manually as I need to  get into my emails as important.
Re: Two-step verification code not working
@shopping
A few things to try:
Check your phone isn't blocking unknown numbers. Go to Settings > Messages > Unknown & Spam > Filter Unknown Senders > Turn off.
If you use message filters on iPhone, make sure all messages are visible. Go to iMessage > Filters > Change to All Messages.
Turn off any VPNs.
Check the spam folder of your messaging app for these texts.
Avatar for shopping
No unfortunately don't work. It's a problem your end since the issues on Thurs. which is when I last received mail. Everything back in but it's the code from yourself not getting through. Can't you disable manually your end. I have logged a complaint ticket with you
Hi @shopping  this isn't sky CS here, you are chatting with fellow customers.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@shopping
" not a Sky employee"
Pretty clear that I do not work for Sky so this is nothing at my end.
Can you not access your email account via an app instead of logging into the Sky website ?
