Discussion topic: Try to port mobile number to sky
Message posted on 28 Aug 2025 06:44 PM
I'm trying to set up a sky mobile phone keeping my number iv registered on l
Message posted on 28 Aug 2025 06:47 PM
Re: Try to port mobile number to sky
@kezbam1 Are you porting your number from another provider?
Message posted on 28 Aug 2025 06:55 PM
Yea I was 02 and have sent pac code
Message posted on 28 Aug 2025 07:03 PM
@kezbam1 What is happening when you add the PAC code to your sim, have you a;readu activated your sim?
Message posted on 28 Aug 2025 07:08 PM
Yes I did it online 3 days ago it says it's still on going
Message posted on 28 Aug 2025 07:19 PM
Are you saying the Sky sim hasn't activated ?
Message posted on 28 Aug 2025 07:27 PM
Yes I still can't use the mobile it's saying emergency calls only when I log on it says the request is still going through
Message posted on 28 Aug 2025 07:29 PM
It should have activated by now so I would try contacting Sky (150 is the number if you have another phone with a Sky sim in it). There are links to their social media sites at the bottom of this page and they can also be contacted via facebook messenger.
Message posted on 28 Aug 2025 07:51 PM
Thanks I will try contact them thanks for help
