Discussion topic: Swap
This message was authored by: AhmedNasirKhawa
Swap
Do u receive swap this is tracking number [removed]
Moderator Actions: Removed tracking information
Re: Swap
@AhmedNasirKhawa
You may not be aware but you haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Your post has been temporarily removed as you posted the tracking number which is a unique number for you. The post will reappear once moderated.
Keep that tracking number indefinitely.
Re: Swap
@AhmedNasirKhawa
If the tracking shows it has arrived then it can take between 2-3 weeks to be processed by the company that handles the returns on behalf of Sky.
