Discussion topic: Sky to sky new sim help
Message posted on 11 Feb 2026 08:58 AM
Message posted on 11 Feb 2026 09:05 AM
Re: Sky to sky new sim help
Hi @Ljw1006 the only way you can do that is buy the new sim/plan and when it arrives activate it. It will have a new number. Then port your old number with a PAC to a different network on PAYG, then port it back to the new sim. You can't port from sky sim to sky sim. If you have had the old sim less than 12 months then there would be early termination charges.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 11 Feb 2026 09:08 AM
Thanks I'll just leave it as is and continue transferring data for now then.
Message posted on 11 Feb 2026 12:11 PM
I need to give my PAK code so my phone works Also I have engineer coming but forgot when he will visit
Message posted on 11 Feb 2026 12:14 PM
I have new sky sim which i have put in my phone I now need to give PAK number to sky from my old privider
Message posted on 11 Feb 2026 12:15 PM
A PAC code is used for moving a mobile number between two different networks so who do you need to gove this to, if it is Sky then you can do it via your account here:
https://www.sky.com/myaccount/mobile/sim/x/my-number/transfer
