Discussion topic: Sky swap return box damaged
Message posted on 05 Aug 2025 04:21 PM
Hi,
I have a swap upgrade with ipad to macbook air but by mistake i have damaged the box but i have the return envelope safe with label inside that ..only return box is damaged so do i need the box also or the envelope inside will work.
or else i would need the return box again to send the product.
thanks
Message posted on 05 Aug 2025 04:25 PM
Re: Sky swap return box damaged
You can either contact Sky to ask them to send you some more packaging or you can use whatever you have got or can get and attache the return label to it. Just make sure that when sending this off that you get and keep the proof of posting receipt.
