Discussion topic: Sky mobile roaming not working when abroad
This message was authored by: Bianca589
I am currently on holiday in Egypt and am a diamond vip customer. As part of a recent offer I should be able to use my device as I do in the UK however it will not connect at all. I have reset my network settings and tried to turn off automatic selection for network but nothing works. I have 3 devices with me and only 1 connects. I am with another family who have 4 devices and also only 1 connects.
Tried to message sky but was told I need to do a factory reset. Surely this is not the solution? We are all android apart from 1 device which is an iPhone. I asked for my request to be transferred to second line support but was refused. I have used chatgpt and done all of their suggested fixes but nothing works. There must be something that can be done.
Re: Sky mobile roaming not working when abroad
As some devices are working it would seem to indicate client configuration issues rather than a network problem.  (A factory reset wouldn't be a good idea)
Check SIM application is set to 'roaming'.
@Bianca589
If you have an Android phone give this a try:
Find the 'Sky Menu' app.
- Select 'Roaming'
- Ensure both 'Automatic' and 'Sky Settings' have '>' in front of them.
Avatar for Bianca589
Thanks for responding. They both are set that way already 😭
@Bianca589
All we can do is to point this out to you:
https://www.sky.com/help/diagnostics/sky-mobile-roaming/roaming-problems
Also trying turning airplane mode on, wait a minute and turn it off again.
Thanks for responding. The settings are set to roaming
Thanks for responding. I have tried these things already and its still not working.
