Discussion topic: Sky Roaming
Message posted on 30 Nov 2024 07:57 PM
Sky Roaming
Currently in Spain with a group and 5/6 people with Sky Mobile have no roaming since yesterday anyone else have this problem? Any solution no way to contact sky until Monday.
Message posted on 30 Nov 2024 08:03 PM
Re: Sky Roaming
Although you don't have to do you have a spend cap set because if you do it needs to be high enough to cover your stay.
That apart have you tried searching for other networks to see if your device will connect and then work ?
Also if your phone is an IOS one try changing the automatic network selection to manual network selection as this will allow you to search for available networks and to connect to one that works for you. You should be able to search for all available networks on an Andriod device as well.
Also make sure this setting is set to Abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
