Discussion topic: Sim replacement not working
Message posted on 08 Feb 2025 08:04 PM
I've bought a new phone from sky as an existing customer around 2 weeks ago and activated my new sim when setting up the phone. However, it still says I need to activate it and I never got the message to say that it activated. Every time I try to replace my old sim it says there's an error. I have a swap upgrade so I'm wondering if it doesn't let me replace the sim until my new phone has been sent back
Message posted on 08 Feb 2025 08:09 PM
Re: Sim replacement not working
When it comes to sims and activating them the phone plays no part in it.
If all you did was to get a new phone so you didn't order a new data plan then usually you should be able to use the sim you had already got in the new phone.
You might have to find a way to contact Sky about this so if you have no other phone they can be contacted via social media.
