Discussion topic: Sim card pin lock default code
This message was authored by: KJ601
Anti scam advice has told me to put a pin code on my sim card as protection. I have never done this before but it asks for my pin number to activate it. Is there a default PIN code and if so what is it?
This message was authored by: daveNOS
Re: Sim card pin lock default code
@KJ601 Try eight zero's.
Avatar for KJ601
Nope, tried it but it suggests possibly the wrong PIN. I tried the Pin i use for the phone initially so that's my two goes and I can't afford to get locked out.
This message was authored by: LauraTibbles
Did you get it sorted, I'm in same position
@LauraTibbles
Did eight zeros work for you ?
