Discussion topic: Signal lost in Tenerife
This message was authored by: MattL2
After 5 days in Tenerife 29 November my Mobile data dropped. 2 days later my sky phone linked to Movistar dropped completely. Same problem as June. No excuses ......what is the problem. Should have been discovered by now. Is there a self serving cap on roaming. ??
Re: Signal lost in Tenerife
It is up to you to set a spend cap if you want to. Not having one set should not cause these issues.
Make sure your device is set to abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
