Discussion topic: Signal loss
This message was authored by: Golfnut66
Signal loss
Around the Swindon Wilts area continually have network issues, resulting in not being able to use the phone properly
Re: Signal loss
@Golfnut66
Does any relevant information show on this link?
https://www.sky.com/help/articles/service-status-sky-mobile
It may disclose a nearby mast issue, but in case you aren't aware Sky don't own or maintain any mobile masts so if there is an issue you and others in the area will be relying on a third party fix.
This message was authored by: GRB57
Re: Signal loss
I have a similar issue around the Cambs Northants area. No calls, or 5G/4G available.
Re: Signal loss
@GRB57
See my reply to the OP immediately above your post.
