Discussion topic: Signal Aboard
This message was authored by: LukeInIndo
Signal Aboard
I'm in Indonesia and need to recive a text message to my UK Sky number, however i'm not getting a signal.
Have worked through the help page, tried selecting network manualy and checked mobile data configuration.
Not sure what else to consider and can't get intouch with sky as no signal.
As far as i know there is no reason why I shouldnt be getting a signal, worked fine in India.
Many thanks
Re: Signal Aboard
@LukeInIndo
Do you have a spend cap set and if so is it high enough to cover your stay.
You are also in a rest of the world country where it is going to work out really expensive for you to use mobile data if you can get it working:
£2,160 per GB (yes this is correct)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS
