Discussion topic: Settings
This message was authored by: Marcianonanau
Settings
Change the settings to +18
Re: Settings
@Marcianonanau
Do you mean you're wanting to remove the parental controls?
If so, then only a credit card will suffice (not a debit card). You can borrow a credit card if you haven't got one yourself, it doesn't have to be yours. The only other way is if you have signed a credit agreement with Sky, then they will already know you are 18 or over so if you call them on 150 they can deactivate this for you.
▪️I AM NOT A SKY EMPLOYEE ▪️
