4
This discussion topic has been answered Discussion topic: Second phone number under same data plan
Hi. Is it possible to get a second phone number under the same data plan (i.e. two different numbers, one an eSIM, one a physical SIM, but both use the same data plan on my account)? Thanks.
Re: Second phone number under same data plan
Each number has to have it's own physical sim/esim and data plan but can be on the same account that the other number is on so can have shared access to the same piggybank.
Thanks. So does that mean I could get a pay-as-you-go SIM (does Sky offer these?), add it to my account, and top it up by rolling data allowance onto it from my piggybank?
Hi @Anonymous  sky don't do PAYG sims, you can get the lowest monthly one available and top that up from your piggybank, but make sure it's ordered on your account if you do decide to do that.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Sky sometimes offer 'free' * 100MB plans - which are ideal for topping up from a piggybank.
* they may not be free forever
