Discussion topic: Samung s26 utra battery
Message posted on 17 Mar 2026 05:38 PM
Does anyone experience that their samsung s26 ultra battery seems to heat up when using one of the apps? For example tiktok?
Message posted on 17 Mar 2026 06:18 PM
Re: Samung s26 utra battery
Hi @Ram02 quite often smart phones do warm up especially if using an app that is heavy on the processor built in. How hot are you feeling it ? If it's just warm I would say it's probably ok and just settling in, if it's to hot to touch or hold then it may have an issue.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 17 Mar 2026 06:35 PM
Its hot to touch especially if im using tiktok. But if i stop using it then its fine.
Message posted on 17 Mar 2026 06:44 PM
A thread from Samsung forum @Ram02
Message posted on 18 Mar 2026 03:07 PM
I've not noticed anything
