Discussion topic: SIM problems
This message was authored by: ELLA37
SIM problems
I've had my phone a while my SIM card is fully activated and has been fine until the past couple of days it keeps cutting off and saying no SIM
Re: SIM problems
@ELLA37
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
If not then if you can call Sky on 150 as they might want to send you a replacement sim to try incase the one you have has developed a fault.
