Discussion topic: Roaming
Message posted on 29 Aug 2026 02:34 PM
Roaming
Can I use my sky mobile in Tunisia
Message posted on 29 Aug 2026 02:37 PM
Re: Roaming
@Tina186 wrote:Can I use my sky mobile in Tunisia
Yes, that location is included in Passport Plus. (£2 / 24 hours)
Message posted on 29 Aug 2026 02:52 PM
Re: Roaming
For that destination it should cost you £2 for each 24 hours use of your home allowance ~ but if you are a Diamond VIP member the daily roaming is free in Roaming Passport Plus destinations.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage due to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-moblle-tair-usage-policy.
