Discussion topic: Roaming
This message was authored by: Bryan1300
Roaming
Can I use my saved data from my piggy bank while touring in the EU.
Re: Roaming
@Bryan1300
Check the below link for the destinations you will be in.
If it's a Roaming Plus location it should cost you £2 for each 24 hours use of your home allowance.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage duel to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Re: Roaming
Yes, subject to the above fair usage limit.
