Discussion topic: Roaming
This message was authored by: Steveod1112
Roaming
I'm in France. Cannot connect to roaming. Have settled spend cap at £10
Re: Roaming
@Steveod1112
Try the troubleshooting in this link
https://www.sky.com/help/articles/sky-mobile-roaming-problems
Alternatively if you've been there for a while could you have exceeded the fair usage policy?
Roaming using Roaming Passport Plus is now limited to 25GB per billing period.
From Skys own website...
When you roam using our Roaming Passport Plus, we consider that up to 25GB per billing period is a reasonable amount of data to use. If you exceed this amount, we'll assume that you're no longer using data in the way expected of a reasonable customer for periodic travel.
We may suspend your service, restrict your usage, or charge you for the data that you use in excess of these amounts (currently £2.50 per GB), and we'll let you know by SMS or email before we do so.
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Avatar for Steveod1112
Re: Roaming
Sorted now.
