Discussion topic: Roaming
This message was authored by: Nat45643r
Roaming
Hi, Could you please advise/ help with roaming / Internet connection? I am in Romania till 14th of June.
Re: Roaming
Hi @Nat45643r   It should cost £2 for each 24 hours use of your home allowance. Make sure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use some data. I would set my monthly spend cap to cover the total number of days you are there. Calls to local numbers are charged extra.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
