Discussion topic: Roaming
This message was authored by: Carol_C1
Message posted on 23 Feb 2025 07:40 PM
Roaming
My phone won't connect to any network whilst roaming in France. I had the same problem in Spain last year.
Find out more
Message posted on 23 Feb 2025 07:47 PM
Re: Roaming
Although you don't have to do you have a spend cap set because if you do it needs to be high enough to cover your stay.
That apart have you tried searching for other networks to see if your device will connect and then work ?
Also make sure this setting is set to Abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
