Discussion topic: Roaming
This message was authored by: Hilpapatel
Message posted on 09 Feb 2025 11:21 AM
Roaming
I need to add 9th and 10th for Roaming
Find out more
Message posted on 09 Feb 2025 11:23 AM
Re: Roaming
You don't have to 'add' roaming - you are charged automatically when used.
What country?
Find out more
Message posted on 09 Feb 2025 11:39 AM
Re: Roaming
Hi @Hilpapatel if you have roaming and mobile data turned on then as soon as you connect to a local network and use some data then roaming will start automatically. Depending on where you are visiting though could be very expensive.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
