Discussion topic: Roaming
This message was authored by Deborah+Akindipe This message was authored by: Deborah+Akindipe
Roaming
Hi I'm on holiday in Portugal and I can't call or text or even use my data it say no signal
This message was authored by 63johnw This message was authored by: 63johnw
Re: Roaming
Hi @Deborah+Akindipe  have you made sure roaming and mobile data are on in your phone settings. Are your spend caps set high enough ? Try searching for and connecting to a different local network.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
