I've put a £20 spend cap on my account as I'm going to Spain. Does that mean I can use my hotspot for my granddaughter
Yes. The £20 spend cap means just that, so you will be charged £2 for every 24 hours you use your data package but once or if you hit the £20 limit you will no longer be able to do this unless you increase the cap limit.
