Discussion topic: Roaming not working in India.
Message posted on 07 Feb 2026 04:46 PM
I am in india. Tried everything in the sky help page. Still just not registering on network. Sky are not helping as usual. Any ideas anyone
Message posted on 07 Feb 2026 04:53 PM
Re: Roaming not working in India.
India is a rest of the world country so if using a Sky sim and especially when using mobile data you could be wracking up some large bills as this is soimething that you are looking at:
£2,160 per GB (yes this is correct)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
So check your spend cap if you are OK with this otherwise get and use a local sim while in the country.
