Discussion topic: Roaming in USA - No Network Connection
This message was authored by JMUR This message was authored by: JMUR
I an in the USA and my Sky Mobile will not connect to a Network Carrier in the USA.
Re: Roaming in USA - No Network Connection
Although you don't have to do you have a spend cap set because if you do it needs to be high enough to cover your stay.
That apart have you tried searching for other networks to see if your device will connect and then work ?
Also make sure this setting is set to Abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
JMUR
Using an Apple iPhone 15
Hi,
Thank you for your response.
Current settings are:
Settings > Mobile Service>eSIMs>Primary>Network Selection> Automatic
Try changing that network setting from automatic to abroad.
JMUR
Hi,
Cannot change from Automatic to Abroad.
Only option is from Automatic to four different Cellular Networks in USA.  Tried changing to all of them and none worked.
