Discussion topic: Roaming in Barbados.
Message posted on 24 May 2025 05:33 PM
What is the best and most cost efficient way to have roaming on in Barbados. I have 3 sims in total across my family.
Message posted on 24 May 2025 05:40 PM
Re: Roaming in Barbados.
Hopefully you're aware of the very expensive costs as it's a Rest Of The World destination. The following charges will apply:
£2,160 per GB
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS).
@IM08 wrote:What is the best and most cost efficient way to have roaming on in Barbados. I have 3 sims in total across my family.
Not using Sky Mobile... Ensure airplane mode is on and use local WiFi.
It's a rest of world location:
£2,160 per GB of data (Yes, that's two thousand)
£2.16 per minute to call UK
50p per text
Calls to local numbers are charged at International rates.
Message posted on 24 May 2025 09:06 PM - last edited: 24 May 2025 09:17 PM
There isn't one with a Sky SIM: you need to look at local provision (Digicel or Flow) or specialist providers of travel eSIMS.
Numerous online sources give advice about mobile provision when travelling in locations not included in a home country plan
