Discussion topic: Roaming data
This message was authored by: Lynne8199
Roaming data
I want to activate my 25gb to my roaming sim please
Re: Roaming data
You do not need to 'activate' roaming as such under your account.
If your phone has roaming enabled and you make calls, texts or use data then it is automatically available (subject to spend cap).
What country are you going to?
