Discussion topic: Roaming charges
This message was authored by: Jason+Hallett
Roaming charges
Is there anything other than turning on roaming to use phone when abroad for iPhone 16
Re: Roaming charges
@Jason+Hallett
For Roaming Passport Plus destinations it should cost you £2 for each 24 hours use of your home allowance ~ but if you are a Diamond VIP member the daily roaming is free in Roaming Passport Plus destinations.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage due to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-moblle-tair-usage-policy.
Re: Roaming charges
@Jason+Hallett
Where will you be going ?
