Discussion topic: Ring tone too short S23
This message was authored by: Lyn3941
Message posted on 01 Jul 2026 05:22 PM
Hi. A recent update means my Samsung S23 goes straight to voicemail. How do I reset the call time?
Find out more
Message posted on 01 Jul 2026 07:20 PM
Re: Ring tone too short S23
Give this a try:
Open your Phone app and tap the Keypad tab.
Dial the following exact sequence: **61*44310*11*XX#Replace the XX with the number of seconds you want your phone to ring.
You can choose 05, 10, 15, 20, 25, or 30. (For example, use 30 to make it ring for the maximum of 30 seconds).
Tap the Call button. A pop-up will appear on your screen confirming that the call forwarding registration was successful
