Discussion topic: Reduce data plan
Message posted on 02 Feb 2025 06:32 AM
Reduce data plan
Message posted on 02 Feb 2025 07:20 AM
Re: Reduce data plan
This link explains what to do. Note that by reducing the plan it won't start until your next billing period
https://www.sky.com/help/articles/change-your-mix
Hi @Andy+and+Gail you can do it via the my sky app if there is a lower plan available. Do it via the mobile tab, tap on the sim in question then tap on manage sim then manage settings and change data plan.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 02 Feb 2025 07:26 AM
Thank you!
Message posted on 02 Feb 2025 07:31 AM
Thank you! As usual, when I'm trying to reduce payment, there seems to be a "technical issue." I'll have to phone them.
