Discussion topic: Random numbers keep ringing my number
This message was authored by: Debbie112
I have loads random people often calling or texting my phone for other people im sick of it
Re: Random numbers keep ringing my number
@Debbie112
I have moved your post from the Accessibility section. As you mention texts I'm presuming this is on your Sky mobile phone.
Unfortunately there isn't a lot you or Sky can do to prevent this. If your mobile number is new to you remember there are very few new numbers and the number you have will almost certainly have been allocated to someone else previously.
Otherwise some of these calls may be scammers trying to obtain personal information so be very wary of replying to any unfamiliar calls/texts.
@Debbie112
Some phones like iphones allow you to set your device so if the number that calls you is not in your contact list then the phone will not ring. The only downside to this is that calls from with held numbers might not get through like those from doctors and hospitals.
