Discussion topic: Primary number problem
This message was authored by: Allan34
Why doesn't sky show as my primary provider in settings, my old provider still shows
Re: Primary number problem
@Allan34
When did you transfer the number over ?
Is this on an iphone ?
If the number isn't correct and it has transferred over have you the refreshing the network settings ?
Avatar for Allan34
I changed the number about 6 weeks ago.
it is on IPhone 15
the number has transferred as my primary number but is showing as my previous service provider
Try refresing the network settings so go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
