Discussion topic: Phone
This message was authored by: Ja58
Phone
Phone has returned back to sky
Re: Phone
@Ja58
If Sky requested it back then usually this is because you have failed the second deeper credit check.
You can call Sky to find out if this is what has happened as they can answer this for you but as Sky is not allowed to view your financial records they can not tell you why you have failed the check. You might want to look into this yourself by signing up to a site that allows you to view your records, one credit checking site they use is Experian so you could sign up to a free trial with them, just remember to cancel.
