Discussion topic: Phone
This message was authored by: Kevin+tester
Phone
Can you track a mobile
Avatar for Kevin+tester
Re: Phone
My husband has misplaced his phone
Re: Phone
@Kevin+tester
No, we are customers like your husband.
Re: Phone
You might be able to do it yourself - depending on what's configured etc.
For an iPhone you can use 'Find My iPhone' for example.
Re: Phone
@Kevin+tester
Sky will not do that for you: cellular triangulation is only carried out at the request of the emergency services or following legal processes.
Location finding may be possible within the functionality of either an Google or Apple user account.
Re: Phone
@Kevin+tester
You might be able to track it via one of these links depending on what phone it is:
https://support.apple.com/en-gb/HT201472
https://support.google.com/accounts/answer/7177579?
https://www.samsung.com/uk/apps/smartthings-find/
