Discussion topic: Phone number transfer help
This message was authored by: SLM2
Ive been with sky mobile for about 2 months. Kept my number from another provider and it has transferred over fine apart from 1 of my contacts. When I call or message my daughter, it is not showing my number. Please help - I've reset both phones, used hers to message mine and I reply to that but nothing has worked.
Re: Phone number transfer help
I presume it is showing the temporary number that came with the sim and not the transferred one, if so what phone do you have ?
Avatar for SLM2
Yes, i think so. It's the pixel 8a
You could try resetting your network settings as per this:
https://www.sky.com/help/devicesupport/device/google-pixel-8/12152/scenario/reset-network-settings?c...
After doing this you will need to setup your Wifi connection again.
Avatar for SLM2
Thank you, that half worked!! Hasn't worked for messages unfortunately.
