Discussion topic: Pac code
This message was authored by: Nicky1011
Pac code
Activating new sim trying to keep old number but pac number not working
Re: Pac code
@Nicky1011
Try activating the sim first then try the option to enter your pac code. If it still doesn't work then once the sim has activated phone Sky on 150 as they should be able to take the code from you.
Re: Pac code
Hi @Nicky1011  are both sims with sky ? You cant use a PAC to port between sky sims.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
