Discussion topic: Not registered on network
This message was authored by: I2005W
Joined sky 2 days ago all OK. Then emergency calls only all yesterday. Checked and said upgrade work finished by 6pm. Still not registering. Says network is fine now. Tried all help guides nothing works. Says sim does not allow connection to sky. As a new customer this is farcical. Any help appreciated.
Re: Not registered on network
@I2005W
Is the phone one you got from Sky ?
Hi @I2005W  have you tried restarting your phone ? Once repair/upgrade work has taken place it can take a day or two for things to settle down.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for I2005W
No just the sim. It worked fine day 1 but after upgrade work in area nothing.
Avatar for I2005W
Yes tried that, resetting mobile settings, connecting manually nothing is working unfortunately
If the phone isn't from Sky do you know if it is unlocked, I know you said it did work previously but if the phone able to take a sim from the Sky network ?
Avatar for I2005W
Yes its unlocked as it worked ok day 1.
@I2005W
You could try ordering a replacement sim to see if that helps so if this link doesn't work:
https://www.sky.com/productsettings/mobile/sim/x/replacement-sim
If you can't then will have to contact Sky, perhaps via social media as there are links at bottom to their sites.
