Discussion topic: Not receiving calls
Message posted on 07 Mar 2025 12:35 PM
Not receiving calls
Message posted on 07 Mar 2025 01:00 PM
Re: Not receiving calls
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
Message posted on 07 Mar 2025 01:06 PM
I've checked on your check the coverage, it says it's fine..... but it isn't. Only can make calls through our Wi-Fi and I'm not receiving all calls , this has been happening for months now. I wish I never changed my mobile to sky now as I never had any problems with Vodafone coverage, this is so frustrating as I'm missing important calls !
Message posted on 07 Mar 2025 01:11 PM
Please advise.....
Message posted on 07 Mar 2025 01:16 PM
As you appear to be able to make calls then have you called Sky on 150 about this as they might want to send you a replacement sim to try incase the one you currently have got has developed a fault. When calling stay silent when asked anything by the bot.
Message posted on 07 Mar 2025 01:21 PM
What does bot mean please ?
Message posted on 07 Mar 2025 01:22 PM
@St+Keyne wrote:What does bot mean please ?
When you call you'll find out... (it's the voice recognition system that tries to 'help')
Message posted on 07 Mar 2025 01:30 PM
If you have managed to avoid a bot when calling any company then you have done well but Sky like others use them to try to 'help'.
Message posted on 04 Sep 2025 12:56 PM
Hi,
I have the exact same issue since moving from Vodafone this week.
