Discussion topic: No signal / mobile data
This message was authored by: Mcmikeski
I have just returned from turkey where I was using esims for signal . Now I have returned to the uk I have no signal / monile daya
Re: No signal / mobile data
@Mcmikeski
If you've very recently returned from abroad try this
Apple:
Settings > Mobile Data > SIM Applications > Make sure this is set to Home.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Home.
Not sure if the eSIM usage changes this.
This message was authored by: patsyann
Signals been down in Birnam/Dunkeld area for 2 days now. Phoned them this morning and was told it will be up and running within 24 hours. We'll see....
