17
This discussion topic has been answered Discussion topic: No Signal for 8 days now
This message was authored by: Liamjamie1
I've had no signal at all for 8 days now so I am unable to make/receive any phone calls or text messages. I have tried numerous times to chat on Facebook messenger to Sky staff but all I get told is that the mast near me isn't working as it should and engineers are working on it. I NEED access to calls and text messages URGENTLY. I am unwell and can't even phone my GP Surgery. Sky, you haven't stuck to the terms of my contract which states you will supply me with unlimited calls and text messages. That is what I am paying for but not receiving these services so I am within my rights to cancel my mobile phone contract with Sky, return my phone and cancel my direct debit payments to you. Please tell me where I return this phone to.
Avatar for Liamjamie1
This message was authored by: Liamjamie1 Answer
Re: No Signal for 8 days now
I've managed to sort the issue by removing my eSIM then reinstalling it. It worked immediately and my phone is back to normal again (thank God). It's awful that the Sky helpdesk didn't give me this advice. All they kept telling me was that the mast in my area was down and engineers was working on it. It doesn't take engineers 8 days to fix a problem so I knew there was obviously something else wrong with my phone.
Whilst Sky may let you terminate the dataplan (minimum term is 12 months) the same does not apply to the handset/credit agreement (unless you are within the cooling off period).
Bear in mind other providers may well be impacted by the same mast issue.
This message was authored by: daveNOS
@Liamjamie1 I have quoted your post and highlighted one part in bold, that part is entirely incorrect, loss of service is not a breach of contract or grounds to just cancel, no provider offers a 100% uninterrupted service as it is impossible to do. You may be offered a goodwill gesture once the mast fault is rectified(you will have to call and ask), but don't just cancel your direct debit as that will lead to further issues.
Quite.  See the contract Here particularly 3.19 - which is why I said 'may' release you without ETC (the 'reasonable time' element).
If you have broadband at home then you should be able to enable WiFi calling?
I am unable to call Sky. I don't have any signal to make/receive phone calls or text messages. Online help is useless.
See section 8.7 of the contract you attached
I don't know of anyone local to me who is experiencing the same problem. See section 8.7 of the contract someone else posted below.
Not sure of the relevance.
It simply states you can cancel (the dataplan) giving 31 days notice (as long not in minimum term) or if you are in a minimum term then you will incur early termination charges (ETC).
Check your roaming settings, particularly the SIM application.  Others have reported this causing issues.
As I said earlier, turn on WiFi calling (if supported).
Otherwise, you'll have to contact Sky by some means to see if they'll release you from the dataplan without ETC.
I have WiFi calling however that doesn't enable me to make/receive phone calls unless using certain apps. It wouldn't enable me to call my GP Surgery ect. I have contacted Sky numerous times and I've been told the mast is down in my area and engineers are working on it.
No.  WiFi calling allows you to make regular calls using the phone app.
https://www.sky.com/help/articles/wi-fi-calling
I already have WiFi calling enabled but it's not working.
You're confusing WiFi calling with apps like WhatsApp. WiFi calling allows you to use your phone exactly as normal, you can call any number just like as if you had phone signal. It is not the same as WhatsApp or Facebook messenger etc which are limited to people who use those apps.
What phone have you got?
Sky mobile uses O2. Do you know anyone on O2, Tesco or GiffGaff in the same area and are they affected by this problem (they will be if it's genuinely a mast problem). That will just confirm it's definitely a mast fault and not something specific to your phone - the WiFi calling not working either makes me wonder if it's really a phone problem.
As stated above, I have WiFi calls enabled but I am still unable to make/receive calls or text messages. I don't know of anyone else experiencing this problem.
I have a Samsung Galaxy Z Fold 7
