03 Jan 2025 07:41 PM
iPhone 6 pro Max
I have no signal/data and Now my texts are not going through and sending as my email and it's saying I'm still with EE and not sky been with you for a week and it's been nothing but problems since joining sky starting to get annoyed have done the troubleshooting to sort everything out, but nothing's working have spoke to technical issues and still not working
03 Jan 2025 07:44 PM
Is your phone displaying EE as the network ?
Is the Sky sim in your phone ?
Did you transfer a number from EE to the Sky sim and if so have Sky told you that the transfer has been completed ?
03 Jan 2025 07:49 PM
Yes it's saying EE as my network
yes the sky sim is in
yes I have had my number send over and it's saying it all done
03 Jan 2025 07:53 PM
Posted by a Superuser, not a Sky employee. Find out moreTry a network refresh:
Go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. If you're using iOS or iPadOS 14 or earlier, tap Settings > General > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
